To do an attribute agreement analysis
main topic see also
1 Choose Stat
> Quality Tools > Attribute Agreement Analysis.
2 Do one of the following:
· If
your data are stacked in one column, enter the data column in Attribute column. In Samples,
enter the column of sample indicators. In Appraisers,
enter the column of appraiser names or numbers.
· If your
data are unstacked and in multiple columns, enter the data columns in
Multiple columns.
Keep the trials for each appraiser together. In
Number of appraisers, type the number
of appraisers. In Number
of trials, type the number of trials.
3 If your data have more than two levels
and are ordinal, check Categories
of the attribute data are ordered.
4 If
you like, use any dialog box options, then click OK.
