To do an attribute gage study (Analytic method)
see
also
1 Choose
Stat > Quality Tools > Gage Study
> Attribute Gage Study (Analytic Method).
2 In Part
numbers, enter the column of part numbers.
3 In Reference
values, enter the column of reference values.
4 Do one of the following:
· When
the binary responses are summarized counts, enter the column of counts
in Summarized Counts.
In Number of trials,
enter the number of trials. In Attribute
label, type the attribute label (the default is Acceptance).
· When
the binary responses are raw data, enter the column of raw data in Raw data. In Attribute
for calculation, type the attribute for calculation, which must
match one of the two distinct responses.
5 In
Lower limit, type
the lower tolerance limit. In Upper
limit, type the upper tolerance limit.
6 If
you like, use any dialog box options, then click OK.
