查看: 621|回复: 0
IEC 60286-1:2017 Tape packaging of components with axial leads on continuous ...
发表于 2017-8-11 13:09:45 | 显示全部楼层 |阅读模式
IEC 60286-1:2017 Packaging of components for automatic handling - Part 1: Tape packaging of components with axial leads on continuous tapes
IEC 60286-1:2017(E) applies to the tape packaging of components with axial leads for use in electronic equipment. In general, the tape is applied to the component leads.
It covers requirements for taping techniques used with equipment for the preforming of leads, automatic handling, insertion and other operations, and includes only those dimensions which are essential to the taping of components intended for the above-mentioned purposes.
This edition includes the following significant changes with respect to the previous edition:
a) a complete revision of the structure (detailed in Annex A) and reworked layout.
Publication type        International Standard
Publication date        2017-07-26
Edition        3.0
TC/SC        TC 40 - Capacitors and resistors for electronic equipmentrss
ICS        31.020 - Electronic components in general
31.240 - Mechanical structures for electronic equipment
Stability date          2024
Pages        12
File size        1057 KB
《品质协会规则》|品质币|品质B2B|手机版|加入协会|联系我们|品质协会(www.PinZhi.org) |网站地图
GMT+8, 2024-4-25 16:29 , Processed in 0.023733 second(s), 6 queries , Gzip On, Redis On.
