查看: 1084|回复: 0
IEC TR 63054:2017 Fire risk analysis and risk reduction measures
发表于 2017-8-11 22:02:26 | 显示全部楼层 |阅读模式
IEC TR 63054:2017 Low-voltage switchgear and controlgear - Fire risk analysis and risk reduction measures
IEC TR 63054:2017(E) applies to the fire risk analysis of low-voltage switchgear and controlgear (hereinafter referred to as "equipment") referring to the IEC 60947 relevant publications, where the following applies:
- only the case where a fire originates (typically under fault or misuse conditions) within the equipment;
- only equipment installed in normal environments. Hazardous environments, for example in presence of combustible materials, is not to be considered;
- only the case of products selected, installed and used according to the manufacturer instructions and installation rules.
In addition, the following cases are not considered:
- faults addressed by IEC TR 61641;
- risks due to smoke emissions;
- double faults, i.e. multiple phenomenon, potentially combined.
Publication type        Technical Report
Publication date        2017-07-26
Edition        1.0
TC/SC        TC 121/SC 121A - Low-voltage switchgear and controlgearrss
ICS        29.130.20 - Low voltage switchgear and controlgear
Stability date          2021
Pages        20
File size        1154 KB
《品质协会规则》|品质币|品质B2B|手机版|加入协会|联系我们|品质协会(www.PinZhi.org)
GMT+8, 2024-3-28 23:50 , Processed in 0.054139 second(s), 7 queries , Gzip On, Redis On.
