楼主: 认证
CISPR 18-3:2017 Code of practice for minimizing the generation of radio noise
发表于 2017-10-29 16:34:44 | 显示全部楼层 |阅读模式
CISPR TR 18-3:2017 which is a technical report, applies to radio noise from overhead power lines and high-voltage equipment which may cause interference to radio reception, excluding the fields from power line carrier signals. The frequency range covered is 0,15 MHz to 3 GHz. This third edition cancels and replaces the second edition published in 2010.
This edition constitutes a technical revision. This edition includes the following significant technical changes with respect to the previous edition:
- localisation system of spark discharges which might contain frequency components up to 3 GHz;
- information regarding equations for predetermination of the radio noise level from HVDC overhead power lines.
Keywords: radio noise from overhead power lines and high-voltage equipment
《品质协会规则》|品质币|品质B2B|手机版|加入协会|联系我们|品质协会(www.PinZhi.org) |网站地图
GMT+8, 2024-4-19 05:35 , Processed in 0.022059 second(s), 5 queries , Gzip On, Redis On.
