To create factorial plots, you must:
For cube plots, you do not need to have response data, but you must create a mixture design first. If you enter a response column, Minitab displays the means for the raw response data at each point in the cube where observations were measured. If you do not enter a response column, Minitab draws points on the cube for the effects that are in your model.
