Stat > DOE > Mixture > Factorial Plots > check Cube > Setup
You can to select the up to 8 2-level factors to include in the cube plot.
Responses (optional): Select the column(s) containing the response data. For cube plots, the response variable is optional. If you do not enter a response variable, you will get a cube plot which only displays the design points. This is a nice way to visualize what a factorial design looks like. When you enter more than one response variable, Minitab displays a separate plot for each response.
Factors to Include in Plots Use the arrow buttons to move terms from one list to the other. Select a term in one of the lists, then click an arrow button. The double arrows move all the terms in one list to the other. You can also move a term by double-clicking it.
Available: Lists all factors in your model.
Selected: Lists all factors that will be included in the cube plot(s). You must plot at least 2 but no more than 8 factors.
