A type of response surface design that does not contain an embedded factorial or fractional factorial design. Box-Behnken designs have treatment combinations that are at the midpoints of the edges of the experimental space and require at least three factors. The illustration below shows a three-factor Box-Behnken design. Points on the diagram represent the experimental runs that are performed:
These designs allow efficient estimation of the first- and second-order coefficients. Because Box-Behnken designs often have fewer design points, they can be less expensive to run than central composite designs with the same number of factors. However, because they do not have an embedded factorial design, they are not suited for sequential experiments.
Box-Behnken designs can also prove useful if you know the safe operating zone for your process. Central composite designs usually have axial points outside the "cube." These points may not be in the region of interest, or may be impossible to run because they are beyond safe operating limits. Box-Behnken designs do not have axial points, thus, you can be sure that all design points fall within your safe operating zone. Box-Behnken designs also ensure that all factors are never set at their high levels simultaneously.
For example, you would like to determine the best conditions for injection-molding a plastic part. The factors you can set are:
For a Box-Behnken design, the design points fall at combinations of the high and low factor levels and their midpoints:
