Cube plot
Use a cube plot to see the factors and combination of settings used in your design. In the example below, you can see the low and high settings for Time (30 minutes and 60 minutes), Temp (250° and 350°), and Thickness (1 and 2).
Optionally, you can add a mean response at each setting.
