To display a line plot with one y and no symbols
example     data     see also
1    Choose Graph > Line Plot > Without Symbols, One Y > OK.
2    Under Without Symbols, choose One Y. Click OK.
3    From Function, choose a function.
4    In Graph variables, enter one or more columns of response data. Minitab displays a separate graph for each column.
5    In Categorical variable for X-scale grouping, enter the grouping variable to be represented on the x-scale.
6    In Categorical variable for legend grouping, enter the grouping variable to be represented in the legend.
7    If you like, use any dialog box options, then click OK.
