Stat > Reliability/Survival > Distribution Analysis (Arbitrary Censoring) > Distribution Overview Plot > Options
You can choose the method used to estimate the parameters. You can also specify the x-axis minimum and maximum, and add your own title.
Estimation Method
Maximum Likelihood: Choose to estimate the distribution parameters using the maximum likelihood method, which are estimated by maximizing the likelihood function.
Least Squares (failure time(X) on rank(Y)): Choose to estimate the distribution parameters using the least squares (XY) method, which are estimated by fitting a regression line to the points in a probability plot.
Show different variables or by levels Choose to display the graphs overlaid on the same graph or on separate graphs.
Minimum and Maximum X Scale:
Use default values: Choose to use the default values for the minimum and maximum X scale.
Use: Choose to enter your own values for the X scale minimum and maximum.
Minimum X scale: Enter a value for the minimum X scale.
Maximum X scale: Enter a value for the maximum X scale.
Title: To replace the default title with your own title, type the desired text in this box.
