Test for Equal Shapes or Scales Across Growth Curves
When your failure/repair data are from more than one growth curve, Minitab first performs an analysis on each growth curve. Then it uses the resulting parameter estimates to provide a likelihood ratio test for:
·    Equal shapes across groups - if you do not provide a known shape
·    Equal scales across groups - if you provide a known shape
·    Equal MTBFs across groups - if the shape is set at 1
The hypotheses for these tests are:
·    H0: all of the shapes (or scales or MTBFs) are equal
·    H1: at least one of the shapes (or scales or MTBFs) is different
Note    These tests are not available for interval data.
