1 Choose Stat > Nonparametrics > 1-Sample Wilcoxon.
2 In Variables, enter the column(s) containing the variable(s).
3 Choose one of the following:
4 If you like, use one or more of the available dialog box options, then click OK
If you do not specify a hypothesized median, a one-sample Wilcoxon test tests whether the sample median is different from zero. |
