For Power and Sample Size calculations, the estimate of s (the population standard deviation or experimental variability) depends on whether you have already collected data.
- For 1-Sample Z or 1-Sample t, use the standard deviation of the sample.
- For 2-Sample t, use the pooled standard deviation (Pooled StDev).
- For Paired t, use the standard deviation of the paired differences.
- For One-way ANOVA, 2-Level Factorial Design, and Plackett-Burman Design, use the square root of the mean square error (MS Error).
For sample size calculations, the data have not been collected yet so s has to be estimated. You can use related research, pilot studies, or subject-matter knowledge to estimate s.
If you would like to specify the difference (effects) in standardized (sigma) units, enter 1 in Standard deviation. |
