You manufacture round metal washers. You want to assess the variability in the thickness of your washers. You plan to measure a sample of washers and to calculate a tolerance interval that includes 95% of the population.
If your sample size is small, then the margin of error may be too large and the tolerance interval may greatly overestimate the variability in the thickness of your washers. You want to know how many washers you need to measure to achieve margins of error of 1% and 2% for the tolerance interval. You also want to know what margins of error you can achieve with samples of 50 or 100 washers.
1 Choose Stat > Power and Sample Size > Sample Size for Tolerance Intervals.
2 Select Calculate sample sizes.
3 In Margins of error, enter 1 2.
4 Click OK.
Session window output
Method
Confidence level 95% Percent of population in interval 95% Margin of error probability 0.05
Sample size for 95% Tolerance Interval
Margin Normal Nonparametric Achieved Achieved Error of Error Method Method Confidence Probability 1% 2480 4654 95.0% 0.049 2% 525 1036 95.1% 0.048
Achieved confidence and achieved error probability apply only to nonparametric method. |
The results of the sample size calculations show that, to achieve a margin of error of 1% using the normal method, you need to collect 2480 observations. In other words, with 2480 observations, the probability that a tolerance interval will contain 96% or more of the population is only 0.05.
If you are willing to accept a 2% margin of error, you need only 525 observations using the normal method.
To achieve a margin of error of 1% using the nonparametric method, you need to collect 4654 observations. With 4654 observations, the achieved error probability is 0.049. In other words, the probability that a tolerance interval will contain 96% or more of the population is only 0.049.
If you are willing to accept a 2% margin of error, then you need only 1036 observations for the nonparametric method. With 1036 observations, you achieve a confidence level of 95.1% and an error probability of 0.048.
