Example of Chi-Square Analysis using Cross Tabulation and Chi-Square
     interpreting results     session command
You are interested in determining whether there is an association between gender and activity level for the individuals in your study. Perform a cimage\SQUARED.gif test for association using raw data.
1    Open the worksheet EXH_TABL.MTW. If you have not already done so, set the value order for the variable Activity.
2    Choose Stat > Tables > Cross Tabulation and Chi-Square.
3    Choose Raw data (categorical variables).
4    In Rows, enter Gender. In Columns, enter Activity.
5    Click Chi-Square. Check Chi-square test, Expected cell counts, and Standardized residuals.
6    Click OK in each dialog box.
Session window output
Tabulated Statistics: Gender, Activity
Rows: Gender   Columns: Activity
           Slight  Moderate    A lot  All
Female          4        26        5   35
            3.462    23.462    8.077
           0.2894    0.5241  -1.0827
Male            5        35       16   56
            5.538    37.538   12.923
          -0.2288   -0.4143   0.8559
All             9        61       21   91
Cell Contents:      Count
                    Expected count
Pearson Chi-Square = 2.487, DF = 2, P-Value = 0.288
Likelihood Ratio Chi-Square = 2.613, DF = 2, P-Value = 0.271
* NOTE * 1 cells with expected counts less than 5
Interpreting the results
The cells in the table contain the counts, the expected counts, and the standardized residual. There is no evidence of association (p=0.288, 0.271) between Gender and Activity. Because slightly less than 20% (one of six) have expected counts less than five, you may want to interpret the results with caution.
