You would like to summarize the heights and weights of the individuals in your study classified by gender and activity level.
1 Open the worksheet EXH_TABL.MTW. If you have not already done so, set the value order for the variable Activity.
2 Choose Stat > Tables > Descriptive Statistics.
3 In For rows, enter Gender. In For columns, enter Activity.
4 Click Associated variables, enter Height and Weight.
5 Under Display, check Means, Standard deviations, and N nonmissing. Click OK in each dialog box.
Session window output
Tabulated Statistics: Gender, Activity
Rows: Gender Columns: Activity
Slight Moderate A lot All
Female 65.00 65.62 64.60 65.40 123.0 124.5 121.0 123.8 2.160 2.735 2.074 2.563 7.70 12.78 21.02 13.37 4 26 5 35 4 26 5 35
Male 72.40 70.43 71.13 70.80 170.0 158.1 155.5 158.4 2.510 2.521 2.649 2.579 19.69 20.58 13.21 18.77 5 35 16 56 5 35 16 56
All 69.11 68.38 69.57 68.73 149.1 143.8 147.3 145.1 4.485 3.532 3.773 3.679 28.80 24.27 21.12 23.87 9 61 21 91 9 61 21 91
Cell Contents: Height : Mean Weight : Mean Height : Standard deviation Weight : Standard deviation Height : Nonmissing Weight : Nonmissing |
Minitab displays the mean, standard deviation, and sample size of Height and Weight, classified by Gender and Activity. For example, the men with moderate activity level have a mean weight of 158.1 lbs, with standard deviation of 20.58 lbs. These values are based on 35 nonmissing observations. The column margins are the overall statistics for all the data. For example, the mean height of all the participants in your study is 68.73 inches.
