To create a table with descriptive statistics
1    Choose Stat > Tables > Descriptive Statistics.
2    Do one or more of the following, depending on your desired table layout:
·    In For rows, enter the columns containing the categories that define the rows of the table.
·    In For columns, enter the up to two columns containing the categories that define the columns of the table.
·    In For layers, enter the columns containing the categories that define the layers of the two-way tables.
3    If you have frequency data, check Frequencies are in and enter the column containing the frequencies.
4    In Display summaries for
·    Click Categorical variables to specify count statistics for categorical variables.
·    Click Associated variables to specify summary statistics for variables associated with the categorical variables.
5    If you like, use any of the dialog box options, then click OK.
