A Minitab Response Optimizer tool that shows how different experimental settings affect the predicted responses for factorial, response surface, and mixture designs.
Minitab calculates an optimal solution and draws the plot. The optimal
solution serves as the starting point for the plot
For example, your company injection-molds a plastic part that must reach certain levels of both strength and flexibility. You would like to find the temperatures and pressures that will give the plastic the maximum strength and flexibility.
The optimization plot shows the affect of each factor (columns) on the responses or composite desirability (rows). The vertical red lines on the graph represent the current factor settings. The numbers displayed at the top of a column show the current factor level settings (in red). The horizontal blue lines and numbers represent the responses for the current factor level. Minitab calculates that strength and flexibility are maximized when all factors are at their highest settings (Press=95, Sealant=75, and Machine=2). |
Sealant is expensive and you would like to see how the responses change when the sealant is set to 50. In interactive mode, you can move the factor level (red) line for Sealant, or enter 50 as the sealant level. The plot shows that with a Sealant factor level of 50, the predicted strength is 197.157 and the predicted flexibility is 135.011. |
