A group of experimental runs conducted under relatively homogeneous conditions. Although every measurement should be taken under consistent experimental conditions (other than those that are being varied as part of the experiment), this is not always possible. Use blocks in experimental design and analysis to minimize bias and error variance due to nuisance factors. For example, you want to test the quality of a new printing press. However, press setup takes several hours and can only be done four times a day. Because the design of the experiment requires at least eight runs, you need at least two days to test the press. You should account for any differences in conditions between days by using "day" as a blocking variable. To distinguish between any block effect (incidental differences between days) and effects due to the experimental factors (temperature, humidity, and press operator), you must account for the block (day) in the experimental design. You should randomize run order within blocks.
