An index of potential process capability, calculated with data from subgroups in your study. CCpk compares the process spread to the distance between a specification limit and one of the following values:
Compare your CCpk value to a benchmark to determine whether to improve your process; many industries use a benchmark value of 1.33.
For example, the process below has an unacceptable CCpk value; it has such a wide spread that even when the mean is on target, the process violates both specification limits.
CCpk = 0.90 |
If you provide no target and only one specification limit, CCpk is equal to Cpk. |
