Data means and fitted means
Used in the cube plots for factorial designs. Data means are the raw response variable means for each factor level combination whereas fitted means use least squares to predict the mean response values of a balanced design. Therefore, the two types of means are identical for balanced designs but can be different for unbalanced designs. Fitted means are useful for observing response differences due to changes in factor levels rather than differences due to the disproportionate influence of unbalanced experimental conditions.
For example, you are investigating how time and temperature affect the yield of a chemical reaction. The two factors each have two levels producing four experimental conditions. This is an exaggerated unbalanced experiment to highlight the difference between the two types of means. All experimental conditions are measured twice except for the time and temperature combination of 50 and 200 which is measured four times. The tables below summarize the experimental design and results.
Number of Observations per Experimental Condition
Temp 150
Temp 200
Time 20
Time 50
Means by Factor Level
Data Means
Fitted Means
Time 20
44.01
44.03
Time 50
47.63
47.02
Temp 150
44.13
44.14
Temp 200
47.55
46.90
The "Time 20" and "Temp 150" data means and fitted means are virtually identical because all experimental conditions involving either one or both of these factor levels are measured exactly twice (top table). However, the combination "Time 50" and "Temp 200" is measured four times which over represents their effects in the raw data means. The fitted means adjust for this and predict what a balanced design would yield.
Related Charting Tools
