Improvement ratio/amount
The improvement that you want a demonstration test to detect. Depending
on the specified distribution, Minitab plots the probability of passing
the demonstration test against improvement as either an improvement ratio
or an improvement amount.
Improvement ratio—the
true value divided by the minimum value you want to demonstrate. For example,
an electronic components supplier has improved the design of a particular
glass capacitor. The lifetime of the existing capacitor follows a Weibull
distribution with a 5th
percentile of 50 hours. They consider a 5th
percentile of 150 hours to be a significant improvement in capacitor life.
Hence, they want a demonstration test for the newly designed capacitor
to pass if the improvement ratio is 150/50 = 3. The POP graph displays
a plot of the probability of passing the demonstration test against the
improvement ratio for the Weibull,
exponential, lognormal, and loglogistic distributions.
Improvement amount—the
minimum value you want to demonstrate subtracted from the true value.
For example, a manufacturer improves the design of a thermostat used inside
a gas water heater. The lifetime of the existing thermostat follows a
normal distribution with a 5th
percentile of 1825 hours. They consider a 5th
percentile of 2010 hours to be a significant improvement in thermostat
life. Hence, they want a demonstration test for the newly designed thermostat
to pass if the true improvement amount is 2010 - 1825 = 185 hours. The
POP graph displays a plot of the probability of passing the demonstration
test against the improvement amount for the smallest extreme values, normal,
and logistic distributions.
