The whole number remainder of a number when it is divided by a given divisor (modulus). In Minitab, this function is represented by MOD (m, n) where m is the number and n is the divisor, and m and n are integers. For example, MOD (23, 10) = 3 because 23 divided by 10 results in a remainder of 3. In standard notation, this is expressed as 23 = 3 (mod 10).
Modular arithmetic, sometimes called "clock arithmetic," is
a system that describes how numbers "wrap around" after they
reach a certain value
Modular arithmetic is important in number theory and can be used to simplify computations of extremely large numbers, because many numbers are equivalent in a given MOD. Modular arithmetic also plays an important role in abstract algebra, cryptography, computer science, and the visual and musical arts.
In Minitab, you can find the MOD of a number using the Calculator.
