Analyze VariabilityCoefficients Table - P-Values |
Use the p-values (P) in the coefficients table to determine which of the effects in the model are statistically significant.
If there are significant interactions, you should look at these first because a significant interaction influences how you interpret the main effects. To use the p-value, you need to:
- If the p-value is less than or equal to a, you can conclude that the effect is significant.
- If the p-value is greater than a, you can conclude that the effect is not significant.
Coded Coefficients for Ln(Std)
Ratio Term Effect Effect Coef SE Coef T-Value P-Value VIF Constant 0.3424 0.0481 7.12 0.001 Material -0.9598 0.3830 -0.4799 0.0481 -9.99 0.000 1.00 InjPress -0.1845 0.8315 -0.0922 0.0481 -1.92 0.113 1.00 InjTemp 0.0555 1.0571 0.0278 0.0481 0.58 0.589 1.00 CoolTemp -0.1259 0.8817 -0.0629 0.0481 -1.31 0.247 1.00 Material*InjPress -0.9918 0.3709 -0.4959 0.0481 -10.32 0.000 1.00 Material*InjTemp 0.1875 1.2062 0.0937 0.0481 1.95 0.109 1.00 Material*CoolTemp 0.0056 1.0056 0.0028 0.0481 0.06 0.956 1.00 InjPress*InjTemp -0.0792 0.9239 -0.0396 0.0481 -0.82 0.448 1.00 InjPress*CoolTemp -0.0900 0.9139 -0.0450 0.0481 -0.94 0.392 1.00 InjTemp*CoolTemp 0.0066 1.0066 0.0033 0.0481 0.07 0.948 1.00 |
For the insulation data, the manufacturer used least squares regression to run the analysis. The coefficients table shows the following effects:
You may want to refit the model excluding the nonsignificant terms.
