Analyze Variability
Coefficients Table - Coefficients
Each term in the model has a coefficient. Use the coefficients to construct an equation representing the relationship between the response and the factors.
To use this equation, use Stat > DOE > Factorial > Predict to calculate the predictions and confidence intervals for predictor values that you specify.
Example Output
Coded Coefficients for Ln(Std)
                             Ratio
Term                Effect  Effect     Coef  SE Coef  T-Value  P-Value   VIF
Constant                             0.3424   0.0481     7.12    0.001
Material           -0.9598  0.3830  -0.4799   0.0481    -9.99    0.000  1.00
InjPress           -0.1845  0.8315  -0.0922   0.0481    -1.92    0.113  1.00
InjTemp             0.0555  1.0571   0.0278   0.0481     0.58    0.589  1.00
CoolTemp           -0.1259  0.8817  -0.0629   0.0481    -1.31    0.247  1.00
Material*InjPress  -0.9918  0.3709  -0.4959   0.0481   -10.32    0.000  1.00
Material*InjTemp    0.1875  1.2062   0.0937   0.0481     1.95    0.109  1.00
Material*CoolTemp   0.0056  1.0056   0.0028   0.0481     0.06    0.956  1.00
InjPress*InjTemp   -0.0792  0.9239  -0.0396   0.0481    -0.82    0.448  1.00
InjPress*CoolTemp  -0.0900  0.9139  -0.0450   0.0481    -0.94    0.392  1.00
InjTemp*CoolTemp    0.0066  1.0066   0.0033   0.0481     0.07    0.948  1.00
Interpretation
For the insulation data, the regression equation is:
Natural log of standard deviation (Strength) = 0.3424 - 0.4799(Material) - 0.0922(InjPress) + 0.0278(InjTemp) - 0.0629(CoolTemp) - 0.4959(Material*InjPress) + 0.0937(Material*InjTemp) + 0.0028(Material*CoolTemp) - 0.0396(InjPress*InjTemp) - 0.0450(InjPress*CoolTemp) + 0.0033(InjTemp*CoolTem)
You may want to refit the model excluding the nonsignificant terms.
Related Charting Tools
