Acceptance Sampling by Variables - Accept/RejectSample Criteria - Sample Size |
Minitab determines an appropriate sampling plan.
Sample Size 259 Mean 0.403108 Standard Deviation 0.0469204 Lower Specification Limit 0.395 Upper Specification Limit 0.415 |
From the lot of 3,600 lenses, the manufacturer and supplier agree to set the acceptable quality level (AQL) to 100 defectives per million and the rejectable quality level (RQL) to 600 defectives per million with respect to the customer's thickness specifications of 0.395-0.415. Using a producer's risk (alpha) of 0.05 and a consumer's risk of 0.10, Minitab determines that an appropriate sampling plan is to randomly select and measure 259 of the 3,600 lenses and compare the data against a critical distance of 3.44914.
