Acceptance Sampling by Variables - Accept/RejectCalculated Criteria - Decision |
If the Zs are greater than the critical distance, and if the standard deviation is less than the maximum standard deviation (MSD), accept the entire lot. Otherwise, reject it.
Z.LSL 0.172803 Z.USL 0.253452 Critical Distance (k Value) 3.44914 Maximum Standard Deviation (MSD) 0.0027533
Decision: Reject lot. |
For each lot of 3,600 camera lenses, you need to randomly select and measure the thickness of 259 of them. From these measurements, Minitab determines the mean and standard deviation to calculate the Z values:
The Zs are less than the critical distance (3.44914), and the standard deviation (0.0469204) is greater than the MSD (0.0027533). Therefore, you must reject the entire lot (Reject lot) of lenses.
