Laney P' ChartGraphs - P' Chart |
The Laney P' chart includes the following elements:
- When your sample sizes are the same or when you choose to use an average sample size, then the control limits will be fixed.
- When your sample sizes vary, then the control limits will vary.
- A value of 1 indicates that no adjustment was necessary and that the Laney P' chart is exactly the same as a traditional P chart.
- A value greater than 1 indicates the control limits were widened to correct for overdispersion.
- A value less than 1 indicates the control limits were narrowed to correct for underdispersion.
You should examine the Laney P' chart for points outside the control limits and trends or other nonrandom patterns.
Minitab conducts up to four tests for special causes for the Laney P' chart, which detect points beyond the control limits and specific patterns in the data. Points that fail a test are marked with a red symbol and the number of the failed test. Complete results are available in the Session window. A failed point indicates that there is an unusual value or a nonrandom pattern, either of which may be the result of special cause variation. These points should be investigated.
The Laney P' chart for the medical record data can be summarized as follows:
To see the same data plotted on a traditional P chart, see Comparing P and Laney P' Charts.
