Laney U' Chart
Summary
The Laney U' chart is similar to a traditional U chart. Both charts help you to monitor the number of defects per unit that are produced by your process. The Laney U' chart can be useful in the following situations:
·    You have large subgroups and your data exhibit overdispersion.
Overdispersion can cause the points on a traditional U chart to appear to be out of control when they are not. For the Laney U' chart, the definition of common cause variation includes not only the within-subgroup variation, but also the average variation between subgroups. If there is overdispersion, the control limits on a Laney U' chart are wider than those of a traditional U chart. The wider control limits mean that only important deviations in your process are identified as out of control.
·    Your data exhibit underdispersion.
Underdispersion, which can occur with subgroups of any size, is often caused by a lack of randomness. Underdispersion can result in control limits that are too wide for the data. The Laney U' chart corrects for underdispersion by calculating narrower control limits.
You can use the U Chart Diagnostic to test for overdispersion and underdispersion.
The calculations for the Laney U' chart include Sigma Z, which is an adjustment for overdispersion or underdispersion. A Sigma Z value of 1 indicates that no adjustment is necessary and that the Laney U' chart is exactly the same as a traditional U chart.
Data Description
The staff at a hospital chain records the number of medication errors each week. Examples of errors include delivering medication at the wrong time, delivering the wrong dose, and delivering the wrong medication.
The hospital chain treats a large number of patients, an average of 7500 per week. The data exhibit a large amount of overdispersion (see U Chart Diagnostic). The staff decides to use a Laney U' chart instead of a traditional U chart to monitor medication errors.
Data: MedicationErrors.MTW (available in the Sample Data folder).
