Multivariate EWMA ChartTest Results - Test Results |
The test results indicate points that are beyond the control limits. A failed point indicates a nonrandom pattern in the data that may be the result of special-cause variation. You should investigate these points.
No points failed the tests for special causes.
For the dinnerware data, the test results indicate that no points are beyond the upper control limit.
