Check assumptions
Before performing a process capability analysis for normally distributed
data you should:
· Make
sure the process is in control. An out-of-control process results in an
incorrect estimate of process capability. Use Minitab's control charts
to determine whether your process is in control.
· Make
sure the data are normally distributed by using Minitab's probability
plot. If the measurements are not normal, you can try to transform the
data to normality using the Box-Cox transformation or Johnson transformation.
