Capability Analysis - Nonnormal
Graphs - Process Data
The process data section of the capability analysis graph consists of the following:
·    Upper and lower specification limits (LSL and USL) - the limits you specified.
·    Target - the target value you specified.
·    Sample mean - the sample mean.
·    Sample N - the total number of observations in your data.
·    Distribution parameters - Parameters for the distribution you chose to fit the data. These can either be estimated from the data or specified in the dialog box.
Example Output
Interpretation
For the electronic device data:
·    Upper and lower specification limits (LSL and USL) - the LSL is 1000 and the USL was not given.
·    Target - the target is 2410.
·    Sample mean - the mean is 2396.53.
·    Sample N - 150 devices were measured.
·    Shape and scale - the parameters for the Weibull distribution. The shape is 8.596 and the scale is 2538.28, estimated using maximum likelihood method.
Related Charting Tools
