I-MR-R/S (Between/Within) ChartTest for Special Causes Results - MR Chart |
The Moving Range (MR) chart assesses whether the between-subgroup variation is in control. Each test for special causes detects points beyond the control limits and specific patterns in the data plotted on the MR chart.
Test Results for MR Chart of Subgroup Means TEST 1. One point more than 3.00 standard deviations from center line. Test Failed at points: 14 |
For the injection molding data, Subgroup 14 failed Test 1 on the MR chart. Test 1 tests for single points that are more than 3 s from the center line. This test provides the strongest evidence for lack of control in a process.
