I-MR-R/S (Between/Within) ChartGraphs - MR Chart |
The Moving Range (MR) chart assesses whether the between-subgroup variation is in control. The MR chart consists of the following:
Minitab conducts up to four tests for special causes for the MR chart, which detect points beyond the control limits and specific patterns in the data. Points that fail are marked with a red symbol and the number of the failed test. Complete results are printed in the Session window. A failed point indicates that there is a nonrandom pattern in the data that may be the result of special-cause variation. These points should be investigated.
The MR chart for the injection molding data can be summarized as follows:
