Variables control charts for individuals are powerful and simple visual tools for determining whether a process is in or out of control.
·    An in-control process exhibits only random variation within the control limits.
·    An out-of-control process demonstrates unusual variation due to the presence of special causes.
In other words, control charts can help you determine whether the process average (center) and process variability (spread) are operating at constant levels. Control charts help you focus problem-solving efforts by distinguishing between common and special-cause variation.
A variables control chart for individuals consists of:
·    Plotted points, each of which represents an individual observation sampled from the process. Minitab plots this value versus a sample number or time, and displays the results in time order.
·    A center line, which represents the expected value of the quality characteristics for all observations.
·    Upper and lower control limits (UCL and LCL), which are set at a distance of 3 s above and below the center line. These control limits provide a visual display for the expected amount of variation. Control limits predict how the process should behave. The control limits are based on the actual behavior of the process, not the desired behavior - they are not specification limits. A process can be in control and yet not be capable of meeting requirements.
Control charts evaluate the pattern of variation for stability through the use of tests for special causes. If you detect special cause variation, you should seek out the factors that contribute to this variation so that you can implement corrective measures.
Related Charting Tools
