Moving Average ChartTest Results |
The test results indicate points that are beyond the control limits. A failed point indicates that a nonrandom pattern exists in the data that may be the result of special-cause variation. You should investigate these points.
TEST 1. One point more than 3.00 standard deviations from center line. Test Failed at points: 28 |
For the plastics data, the test results indicate that subgroup 28 is beyond the control limits. Investigate why this point is out of control.
