Comparisons (GLM)Multiple Comparisons |
Use the adjusted p-values provided with the hypothesis tests to determine whether pairs of means are different. These p-values are adjusted to maintain the family error rate at the desired a-level (in this case 0.05):
The simultaneous confidence level is particularly important when you perform multiple comparisons. For any given individual confidence level, the chance that at least one confidence interval does not contain the true difference increases with the number of comparisons. Consequently, the simultaneous confidence level is always lower than the individual confidence level for multiple comparisons.
The individual confidence level is the percentage of times that a single confidence interval includes the true difference between factor levels if the study were repeated multiple times.
The simultaneous confidence level is the percentage of times that a group of confidence intervals all include the true differences between factor levels if the study were repeated multiple times.
Dunnett Simultaneous Tests for Level Mean - Control Mean
Difference of Subject Difference SE of Simultaneous 95% Adjusted Levels of Means Difference CI T-Value P-Value 1 - 4 -0.6900 0.0750 (-0.8734, -0.5066) -9.20 0.000 2 - 4 -0.0333 0.0678 (-0.1991, 0.1324) -0.49 0.921 3 - 4 0.2733 0.0721 ( 0.0970, 0.4497) 3.79 0.002
Individual confidence level = 98.00% |
For the salary analysis, comparisons were requested between the mean for subject 4 (the designated control level) and the means for all other levels of the subject factor. The confidence intervals for the comparisons reveal the following:
