Comparisons (GLM)Multiple Comparisons |
Use the adjusted p-values provided with the hypothesis tests to determine whether pairs of means are different. These p-values are adjusted to maintain the family error rate:
The simultaneous confidence level is particularly important when you perform multiple comparisons. For any given individual confidence level, the chance that at least one confidence interval does not contain the true difference increases with the number of comparisons. Consequently, the simultaneous confidence level is always lower than the individual confidence level for multiple comparisons.
The individual confidence level is the percentage of times that a single confidence interval includes the true difference between factor levels if the study were repeated multiple times.
The simultaneous confidence level is the percentage of times that a group of confidence intervals all include the true differences between factor levels if the study were repeated multiple times.
Bonferroni Simultaneous Tests for Differences of Means
Difference of Subject Difference SE of Simultaneous 95% Adjusted Levels of Means Difference CI T-Value P-Value 2 - 1 0.6567 0.0664 ( 0.4702, 0.8431) 9.89 0.000 3 - 1 0.9633 0.0708 ( 0.7645, 1.1621) 13.60 0.000 4 - 1 0.6900 0.0750 ( 0.4796, 0.9004) 9.20 0.000 3 - 2 0.3067 0.0632 ( 0.1294, 0.4839) 4.86 0.000 4 - 2 0.0333 0.0678 (-0.1569, 0.2236) 0.49 1.000 4 - 3 -0.2733 0.0721 (-0.4757, -0.0710) -3.79 0.004
Individual confidence level = 99.17% |
Pairwise comparisons were conducted for the subject factor of the salary analysis. Because there are four levels of subject, this produces six pairwise comparisons. The hypothesis tests for the comparisons reveal the following:
