General Linear Model (GLM)Coefficients |
Use the p-values to determine which coefficients in the model are significantly different from zero (no effect).
For categorical factors, the coefficients table lists the estimated coefficients for each level of each factor. The table also lists all combinations of factor levels for interaction effects. Before you look at the effects for specific levels in the coefficients table, you should look first in the analysis of variance table at the p-value for each term. After you identify a significant set of effects (for example main effects, or interaction effects), use the coefficients table to evaluate the individual effects.
If the analysis of variance table suggests significant higher-order or interaction effects, you should look at them first because they will influence how you interpret the main effects. To use the p-value, you need to:
- if the p-value is less than or equal to a, conclude that the effect is significant.
- if the p-value is greater than a, conclude that the effect is not significant.
Coefficients
Term Coef SE Coef T-Value P-Value VIF Constant 2.7275 0.0245 111.29 0.000 Subject 1 -0.5775 0.0443 -13.04 0.000 1.87 2 0.0792 0.0380 2.08 0.045 1.44 3 0.3858 0.0418 9.23 0.000 1.60 Degree 1 -0.3400 0.0373 -9.11 0.000 1.85 2 -0.2600 0.0355 -7.33 0.000 1.92 Subject*Degree 1 1 -0.0100 0.0676 -0.15 0.883 3.53 1 2 0.0600 0.0666 0.90 0.374 3.42 2 1 -0.0167 0.0561 -0.30 0.768 2.14 2 2 -0.0267 0.0532 -0.50 0.619 2.03 3 1 -0.0233 0.0660 -0.35 0.726 2.80 3 2 -0.0033 0.0576 -0.06 0.954 2.42 |
For the salary data, the results can be summarized as follows:
