The degrees of freedom are used to calculate the mean square (MS). In general, the degrees of freedom measure how much "independent" information is available to calculate each sum of squares (SS).
Note
DF for total = DF for all factors + DF for all interactions + DF for error.
DF total = n - 1 where n is the total number of observations.
DF for factor = k - 1 where k is the number of the factor levels.
DF for Interaction = (k1 - 1) * (k2 -1) where k1 is the number of levels of factor one, and k2 is the number of levels of factor two. The same rule applies to interactions of more than two factors.
Related Charting Tools
