General MANOVA
MANOVA for Plant - Eigen Analysis
Use the eigen analysis to assess how the response means differ among the levels of the different model terms. The eigen analysis is of E-1 H, where E is the error SSCP matrix and H is the response variable SSCP matrix. These eigenvalues are used to calculate the MANOVA tests. Place the highest importance on the eigenvectors that correspond to high eigenvalues.
Example Output
EIGEN Analysis for Plant
Eigenvalue  0.1040  0.01571
Proportion  0.8687  0.13126
Cumulative  0.8687  1.00000
Eigenvector         1         2
Usability    -0.01842   0.16312
Quality       0.12789  -0.05649
Interpretation
For the door lock data, the first eigenvalue for plants (0.1040) is greater than the second eigenvalue (0.01571), so place higher importance on the first eigenvector. The first eigenvector for plant is -0.01842, 0.12789. The highest absolute value within this vector is for the response quality, implying that quality means have the largest difference between the factor levels for plants.
