Graphical Summary
Table of Statistics - Anderson-Darling Normality Test
The Anderson-Darling normality test can help you determine whether the data follow a normal distribution. The Aimage\squared.gif statistic that the test provides is not very informative by itself, but it is used to determine the p-value. The p-value ranges from 0 to 1, and indicates how likely it is that your data follow a normal distribution.
First, you need to decide how low the p-value must be for you to conclude that the data are not normal. (A commonly chosen value is 0.1.) Then, if the p-value is lower than your criterion, you must conclude that the data do not follow a normal distribution. Otherwise, there is not enough evidence to conclude that the data do not follow a normal distribution.
Example Output
 A-Squared 0.99
 P-Value 0.008
 Mean 3.6364
 StDev 2.3779
 Variance 5.6545
 Skewness 2.11078
 Kurtosis 5.61936
 N 11
 Minimum 1.0000
 1st Quartile 2.0000
 Median 3.0000
 3rd Quartile 4.0000
 Maximum 10.0000
The Anderson-Darling normality test statistics are located in the upper right corner of the Graphical Summary.
Interpretation
The value of A-Squared for the precipitation data is 0.99, and the associated p-value is 0.008. Assuming you chose 0.1 as the level of significance, you must conclude that the data do not follow a normal distribution, because 0.008 is lower than 0.1.
