Graphical SummaryTable of Statistics - Median |
The median (also called the 2nd quartile or 50th percentile) is the middle observation in the data set. It is determined by ranking the data and finding observation number [N + 1] / 2.
If there are an even number of observations, the median is extrapolated as the value midway between that of observation numbers N / 2 and [N / 2] + 1.
The median is less sensitive to extreme values than the mean. Therefore, the median is often used instead of the mean when data contain outliers, or are skewed.
Anderson-Darling Normality Test A-Squared: 0.99 P-Value: 0.008
Mean 3.6364 StDev 2.3779 Variance 5.6545 Skewness 2.11078 Kurtosis 5.61936 N 11
Minimum 1.0000 1st Quartile 2.0000 Median 3.0000 3rd Quartile 4.0000 Maximum 10.0000
The median is listed in the middle of the Graphical Summary.
In the precipitation data set, there are 11 (non-missing) observations. Thus, the median is the value of observation number [11 + 1] / 2, or the 6th highest observation, which is 3:
1 2 2 3 3 3 3 4 4 5 10
Notice the median of this data set would be 3 even if there were 30 days with precipitation in April instead of 10.
