Suppose that you are conducting a hypothesis test. Recall that the decision to reject the null hypothesis (H0) or fail to reject it can be based on the p-value and your chosen level of significance (a-level). If the p-value is less than or equal to a, you reject H0; if it is greater than a, you fail to reject H0.
Your decision can also be based on the confidence interval (or bound) constructed using the same a-level. For example, the decision for a test at the 0.05 level of significance can be based on the 95% confidence interval:
·    If the reference value specified in H0 lies outside the interval (that is, is less than the lower bound or greater than the upper bound), you can reject H0.
·    If the reference value specified in H0 lies within the interval (that is, is not less than the lower bound or greater than the upper bound), you fail to reject H0.
Related Charting Tools
