Paired tTest of the Differences - Hypotheses |
When you use the paired t-procedures, you are really trying to decide which of two opposing hypotheses seem to be true, based on your sample data:
- or -
Paired T for Before - After
Before 15 74.667 3.478 0.898 After 15 72.333 3.200 0.826 Difference 15 2.333 3.352 0.866
95% CI for mean difference: (0.477, 4.190) T-Test of mean difference = 0 (vs ≠ 0): T-Value = 2.70 P-Value = 0.017 |
In the heart rate example, you have heart rates for a sample of people measured before and after an exercise program, and you want to know the following: Based on the sample data, is it likely that the heart rates both before and after the exercise program are the same? In other words, is the mean difference between before and after measurements equal to zero? Thus, your hypotheses are H0, the mean difference = 0, and H1, the mean difference ≠ 0.
