Principal Components
Eigenanalysis - Coefficients
The principal components are the linear combinations of the original variables that account for the variance in the data. The maximum number of components extracted always equals the number of variables. The eigenvectors, which are comprised of coefficients corresponding to each variable, are used to calculate the principal component scores. The coefficients indicate the relative weight of each variable in the component. The bigger the absolute value of the coefficient, the more important the corresponding variable is in constructing the component.
Note
You must standardize the variables to obtain the correct component score.
Example Output
Variable             PC1       PC2       PC3       PC4       PC5
Income             0.314     0.145    -0.676    -0.347    -0.241
Education          0.237     0.444    -0.401     0.240     0.622
Age                0.484    -0.135    -0.004    -0.212    -0.175
Residence          0.466    -0.277     0.091     0.116    -0.035
Employ             0.459    -0.304     0.122    -0.017    -0.014
Savings            0.404     0.219     0.366     0.436     0.143
Debt              -0.067    -0.585    -0.078    -0.281     0.681
Credit cards      -0.123    -0.452    -0.468     0.703    -0.195
Variable             PC6       PC7       PC8
Income             0.494     0.018    -0.030
Education         -0.357     0.103     0.057
Age               -0.487    -0.657    -0.052
Residence         -0.085     0.487    -0.662
Employ            -0.023     0.368     0.739
Savings            0.568    -0.348    -0.017
Debt               0.245    -0.196    -0.075
Credit cards      -0.022    -0.158     0.058
Interpretation
For the loan applicant data, the first principal component's scores are computed from the original data using the coefficients listed under PC1:
PC1 = 0.314 Income + 0.237 Education + 0.484 Age + 0.466 Residence + 0.459 Employ + 0.404 Savings - 0.067 Debt - 0.123 Credit cards
The interpretation of the principal components is subjective and requires knowledge of the data:
·    Age (0.484), Residence (0.466), Employ (0.459), and Savings (0.404) have large positive loadings on component 1, so label this component Applicant Background.
·    Debt (-0.585) and Credit cards (-0.452) have large negative loadings on component 2, so label this component Credit History.
·    Income (-0.676) and Education (-0.401) have large negative loadings on Component 3, so label this component Academic and Income qualifications.
