Binary Fitted Line PlotBinary Fitted Line Plot - Summary Statistics |
The model summary table contains statistics that you can use to select a model. The statistics include:
, the
better the model fits the data.
that has been adjusted for the
number of terms in the model. Use the adjusted statistic to compare models
with different numbers of predictors.
Use these statistics to compare different models. High R2 values and low AIC values do not guarantee that a model fits the data well. Use the goodness-of-fit tests in addition to the model summary to assess how well a model fits the data.
Model Summary
Deviance Deviance R-Sq R-Sq(adj) AIC 3.41% 1.95% 69.99 |
For the health care center data, the model explains 3.41% of the deviance. The adjusted deviance R2 is 1.95%. A lower value of adjusted deviance R2 is typical when the term in the model is not statistically significant. The AIC is 69.99.
