Fitted Line PlotRegression Table - S, R-Sq, and R-Sq(Adj) |
S, R
and adjusted R
are measures of how well
the model fits the data.
(R-Sq) represents the proportion
of variation in the observed response values that is explained by the
predictor(s).
(R-Sq(adj)) is a modified
R
that has been adjusted for the number of terms in the
model. If you include unnecessary terms, R
can be artificially
high. Unlike R
, adjusted R
may get smaller
when you add terms to the model.
The regression equation is Stiffness = -21.53 + 3.541 Density
For the particleboard data, the S is 8.86937 units of stiffness. Additionally, 84.5% of the variation in stiffness is explained
by density. The adjusted R
is 83.9%.
