Two-Sample Equivalence TestPower and Sample Size |
Use to calculate one of the following parameters for a 2-sample equivalence test:
When you enter values for any two of these parameters, Minitab solves for the third. See, Power for equivalence tests for further discussion.
Data Description |
You plan to test whether the amount of active ingredient in a generic brand of pain reliever is within 1 mg of the amount in a popular brand of pain reliever. You want to determine the sample size that is required to achieve a power of 0.9 for the test. From previous samples, you estimate that the standard deviation is 0.41.
